Thread: squeaky seat
Created on: 07/19/13 10:27 AM
motero
motero's Gravatar
squeaky seat
07/19/13 10:27 AM
anybody elses seat making noise as it rubs off gas tank? what you guys use to stop it?
2012 black zzr 1400,
sherco 290
sherco 305
omega2k
omega2k's Gravatar
RE: squeaky seat
07/19/13 11:01 AM
I dont have that issue. Have you taken your seat off? I know some people have removed their seats and not gotten them back on correctly. Some have even bent the seat tabs at the base of the tank.
2012 ZX14r / 2002 VTX 1800c
_______________
Intelligence Has a Price...
-ME
motero
motero's Gravatar
RE: squeaky seat
07/19/13 11:34 AM
yep, seat defo properly aligned, squeaks like a mo fo
sherco 290
sherco 305
RE: squeaky seat
07/21/13 3:36 PM
it should be solid once mounted correctly with seat tabs in and lined up, haven't heard of this one, check the rear seat rubbers mine where not against the frame rails at one point had to remove and reinstall the seat, it was out of the tabs up front.
RE: squeaky seat
07/21/13 4:28 PM
That latch setup is so fit&finish, I can blow on the back of the seat and both latches dial right in. I dropped the seat once, figured it stay above the hooks? Closed right up I had this big smile. So it's boat grease at the steel latches, or look for the rub marks on the seat pins. Dab vasoline if you want. Use a q-tip to touch some at the rub marks, then swab the rest off on the rubber bumpers.
